How often do you top up your Beemer
Nattsg
Just a rough gauge, please post your regular top up intervals:
1.) Engine Oil
2.) Coolant
3.) ATF
Provided the following is ok:
  • No leaking that you can see below your car
  • its a beemer
  • below 5 years old in SG
I just topped up my coolant by around 600ml during my routine inspections, and 1 litre of engine oil recently too when the car warning came up. For now, i have had the habit to physically check at least the lot floor when I drive off, havent spotted any spots to indicate leakages yet.
Re: How often do you top up your Beemer
Engine oil: 1 ltr every 8000km
Coolant: never needed to top up.
ATF: at 40,000 km
1.) Engine Oil - 4000KM 1 Litre
2.) Coolant - Flushed Every 30000KM together with ATF change.
3.) ATF - 30000KM
u guys are scaring me, no coolant ever??? something must be wrong with my car!
1. Engine oil change every 10k km (never need to top up)
2. Coolant - none (I always flush the radiator once a year, its cheap)
3. ATF - change ATF at 30k km, ATF plus filter pan at alternate 30k km. Done this to my previous E60 since day 1 until 8 years old before sold off, gearbox nvr have any issues.
I same as VIper Warrior ..... Except ATF @ 40k
1.) Engine Oil - 5-9,000 max (depend smoothness of delivery, lousy oil, 5,000km. good oil 9,000)
2.) Coolant - (none except when coolant tank burst or pipes leak)
3.) ATF - (30- 40,000km - DCT oil)
4. ) rear axle oil (40,000km)\
TS, when u check the floor before drive off is not required ...
if there is leaks means big problem.. remember we have a pan and cover beneath our engine bay.
monitoring my coolant levels then.... So many here say no need to top up coolant i have topped up twice in a year >
Have you sent your car for servicing yet? The workshop should be able to detect coolant leaks from its stains on other parts in the engine bay.
debet39com
