I want them rears to STICK OUT!
ACS6
Dammit.....now thats phat! LOL......superwide tyres plus super deep dished rim plus 50mm spacers? Now thats da shite!
Re: I want them rears to STICK OUT!
Swee,
Swee.. Lst time someone posted a video os black s600 in japan.. That one I see liao cock steam
I saw one black E60 in Pasir Ris with fat rear tires and kim kim rims, the wheel arch also protrude out like the pix at top. I think as long as the arch is within the maximum width of the car, i.e inside the side mirror dimension, it MAY be acceptable. Bros, interested should check with LTA.
It's gonna rub like crazy.......
Mai siao siao last time my rim also stick out I camber in..
Kena caught by rov.. 50bucks fine.. Nnb
i like the diffuser. hahahaha
I almost died when I saw this comment.... :lol2:
Must be the way you drive lah. Mine right now also hanging out and camber in with KW V3s...so far so good. Touch wood. Drive beside ROV at Sin Ming a few times already, they boh chap me coz my ACS rear wing too small. Not BOOMZ enough.
But Kenn is right, it'll rub like hell even if you set the compression and rebound in the coilovers to the max hardness...you'll never be able to avoid rubbing the arches.
steroiduser88;489639 said:
shit man when i saw the rims
machiam die cock stand. gosh ill give u my girlfriend for those rims!
ON! But WAIT...you pm me your gf pix first. Just in case she is Ris Low.
Haha steady ah bro. Her accent is worse than ritz low u still want not!
Any bros in singapore have that kinda rims?
I'm also curious to find out. But I think the tyres itself can buy coilovers for my ride.
It is easy to try this set-up with spacers. Test it for one week and see how you could tolerate. Reversible process.
if u run on 1000lbs spring rates then no rub
guys, the hardest spring rates i could get from KW clubsport was 800lb/in german steel with rebound set to hardest.
still rub though fender is 2cm off the rubber. even after we lightened the rear-end of the car with full tit exhaust and lightened batt with nothing in the boot, still rub if cornering and over slight bump even when fuel tank is nearly empty!
in this case sure to rub fender with rubber!
LOL...yep. Agree with you monster. My KWV3 almost set to the max liao but still can't avoid rubbing the fenders sometimes when I hit the throttle hard down our lovely undulating roads, ala CTE. It shits me most when the passenger hears it and gives me that look like "WTF is wrong with your car?"....LOL...priceless
SHINGZ!
At 2cm apart and rub...that is because the rub is probably in the inner wheels!
snaptikteam
