iDrive chinese fonts and disable low fuel warning?
L3stat
Hi guys, does anyone know if it's possible to display chinese fonts in iDrive? Have a bunch of ID-tagged songs in an iPod, shows up as squares now. Also, possible to disable the low fuel warning through coding? A warning at quarter tank feels way too early.
Re: iDrive chinese fonts and disable low fuel warning?
Disable low fuel warning? Really??
Yep, I don't need it. That's what the fuel gauge is for... It's annoying to me when it comes up too early.
When you reach zero on the F10.. it is really zero. When it alerts you, you only have 80kms left to go.
Don't run your tank low. You will damage your fuel pump.
iDrive can show chinese ... it's the instrument cluster that shows ?????
if you want instrument cluster also show chinese fonts ... must upgrade to 6WB :thumbsup:
I have the E90, alert comes on when there's a quarter tank left.
wt_know, which car are you driving? Mine just shows boxes for Chinese song names. My instrument cluster is in English and I have no intention to change that.
The fuel warning will always be there .... But it can be reduced from 1/4 to e.g 1/8 tank .....
my ride is f10 with nbt idrive
your e90 should be CIC and it should be able to display chinese (i asume only)
make sure your mp3 id tag and title is done properly
may be you can check with elebest max
hitclubwinvip
