ignition coil
sukoo
New Member
jus wan to check wif u guy
the older version of bmw should use the external coil
any idea which modal use one is the most powerful coil?
and where can i buy the coil
thank
Sukoo....I believe you are refering to the M20 engines ??
After that...most of the BMW engines are using the build in coil from the M50 onwards.
If you are looking for external coils and more powerful ones, you might wanna check with Cartronic (ptc Kimiko) and see if she has ex stocks of Hanshin coils. These bugger generate around 40Kv as compared to the 18Kv that the Bosch is doing.
oic thank for ur valuble reply
can i haf the contact ?
do u roughly noe wat the price range?
last question jus to check wif u
compared to those merz used external coil
which one will haf more spark?
so if i call to ask
will i get a better deal if mention ur name
hee hee
pg88comim
