thatboyhaikal
New Member
Send the car to pml to have it checked. SA says its normal. Even the techs says its normal too. Any suggestions?
splee;1092330 said:I have it on my f30 too. It's a common problem for the f30s. It happens when you are going over uneven road surface. I understand it's from the ball joint of the stock absorber which is made of some plastic material. Changing to after market suspension setup will resolve the knocking sound.
Red_Bean_Bun;1092348 said:Shock absorber got ball joint ?
If its an adaptive suspension it will be a waste to change to aftermarket suspensions...
splee;1092654 said:I am not sure. Probably the suspension mounting or something and it's made of plastic and this is the culprit causing the knocking sound. After changing to aftermarket Coilover, problem solved.
