Re: Lower Down the Car
:nehnehhh: it is beacuse the springs is the cheapest choice in lowering the car and the least cost .
they charge you $1500 - $500 = $1000 on labour + profit
:singsing:
KW sports suspensions ( complete suspension systems ) consist of
• 4 high-quality lowering springs
• 4 specially matched sports shock absorbers, which have a shortened stroke and are adapted to suit the new conditions.
Retail from : S$1200 ( depends on makes / model of vehicle )
The KW sports suspensions range has been developed to supplement the well-known, individually applicable KW screw-adjustable suspension system.
The aim of this range is to use existing resources, expertise gleaned from Motorsport and direct access to top-quality materials, combined with a perfectly organized industrial production facility, to create complete, vehicle-specific suspension solutions. To create improved looks and handling characteristics, to match OEM quality, and to achieve an outstanding price/performance ratio. The resulting KW suspensions complete suspension system meets these high demands in terms of functionality, quality and price.
• Vehicle-specific development
• Optical and driving-dynamic improvements
• High-quality materials and the latest production
• Excellent price/performance ratio
The aim of the extensive raod tests is to achieve optimum interaction between the shock absorber/spring unit and to enable significant improvements in handling and road-holding. The sporty, hardmonised tuning delivers excellent road-holding and safety, without the uncompressing loss of residual comfort.
• high-quality springs with specially matched sports shock absorbers
• sports shock absorbers with shortened stroke
• optimum interaction between shock absorber / spring unit
• signifi cant improvement in handling and driveability
• sporty, harmonised tuning
KW suspensions lowering springs are suitable for reducing the height of the vehicle by up to 60 mm. In addition to the improved looks, the lowered centre of gravity contributes to increased agility and driving pleasure. Lowering springs up to 40 mm can be used with standard shock absorbers. In general, however, the use of sports shock absorbers is recommended, and is a compulsory requirement for any further lowering.
• lowering from 40 to 60 mm, including wedge shape
• lowered centre of gravity
• improved looks
• increased agility and driving pleasure
• OEM quality according to DIN ISO
All KW sports shock absorbers are developed and tuned specifically for their intended use. KW engineers use all the knowledge they have gained from suspension development and motorsport in order to find the perfect tuning in extensive road testing
The double-tube gas shock absorbers are generally equipped with hardened, chrome-plated piston rods, offering ideal protection against stone chips and corrosion. A new, innovative monoblock guide and seal package inccreases pressure resistance, reduces friction and hence promotes efficiency. The new, V-shaped shrink fit Teflon seals on the working pistons reduce to a minimum the losses due to friction, and guarantee an extremly temperature-resistant, durable shock absorber system. All KW sports shock absorbers are equipped with a rebound (shortened stroke), guaranteeing optimum stroke rations and ensuring that springs are pre-tensioned. A large proportion of the rear axle shock absorbers are equipped with spring plates that are adjustable by means of slots, enabling the height of the vehicle to be varied in 5 additional positions.
