altreality
The bulb size is 9006.
kenntona said:If you are still referring to fog lights, try size HB4 4,500 K (some Jap or Taiwanese brand) that is sold in Autobac. $120 per pair, but damn white. Blends with Philips Diamond Vision 5,000 K. I am assuming you are using the Hella pre-facelift fogs. But they do have the same brand for facelifted models.
Don't think you can go higher kelvin than that. The higher the kelvin ratings, the more bluish is the light, the shorter is the wavelength, and thus is less visible at a longer distance. Hence defeats the purpose if you want a further throw from your lights.
Azrielsc said:1. Xenon lights are 4.3k
2. Fog lights are stock.
So to change my fogs' brightness and colour to match my xenons, I have to get HB4 4,500k bulbs. Is that correct?
kenntona said:That's what I would do.
Unless you wanna go for 4,300 K HB4 - if they carry that (Silver Vision).
Just to share - I am using 5,000 K Diamond Vision for my H7, and 4,500 K HB4 for fogs. The cluster looks blended, except for the yellow "pearl" in my highbeam cups. Once the CCFL is installed, the "pearl" will be removed for the cables, and the whole cluster will look uniformly whitish when lit.
Azrielsc said:Ken,
Am i correct to assume that u have HIDs too? If u do, i'll be following your configuration as well, , 5K Diamond Vision for my H7s, and 4,500 K HB4 for fogs!
As for the yellow "pearl", i think i'll keep it to give a nice contrast to the rest of the headlights!
Thanks!
CyberTron said:Cheapest so far I find for the Philips Diamond Vision H7 is $68, no GST, cash payment, but no installation. Installation was a bit siong to my standard especially for the passenger side.. very cramp
hmm... was asking the shop for Diamond Vision for the HB4, like dun have.
Think there's only Bluevision for the HB4, which is 4300K I think. Anyway, still yet to replace my fog since I hardly on my fog.
I installed the Diamond Vision, I feel is just a little too white, but since is high beam, I also hardly use, so is ok for me.
Now looking for 6000K xenon that's not as ex as Philips ones but as bright as that.
