need help on e36 318i sedan....
rudees
Hi all,
am a newbee here and just got myslf a e36 318i a few mths back, firstly when i got the car there was a leak from the fuel tank, got that repaired but now when I stop my engine or when I just crank it up i can smell petrol and don't know where it's coming from.So is that normal? Secondly there's a trick trick sound coming from the right side of the drivers air con vent what's happening? Pls advice need all of your expertise on this problem. Thanks everyone
Re: need help on e36 318i sedan....
check ur fuel pipe... i had tis prob....
hi bro ,i had my fuel pump and the fuel pipe change as well did it at juzz 4 cars.
oh, i tot the one under the carraige. what was the cost when u changed yours bro?
jus change the pipe lor.. cos old liao cracked ezly... i forgot how much but shld b cheap.
i wld not rec that plc to u ... cos i don go there animore... haha....
yeah....most likely the rubber seal in the fuel tank that's causing this problem.Had mine replaced a couple of yrs back when I was facing the same problem as u.
kena chop cai tao??? :nehnehhh:
by the way, just saw one damn chio E36 coupe opposite your Changi Road office, its rite outside those HDB flats....damn good condition
and ya, saw a smashed up E36 coupe outside my workshop, same color as matagia's ride but plate is SG something......sayang sia :(
sszone;290462]kena chop cai tao??? :nehnehhh:
not reali la... but wun reali rec ppl there cos i nv go there le ma...
wat colour? black?
and ya, saw a smashed up E36 coupe outside my workshop, same color as matagia's ride but plate is SG something......sayang sia :([/QUOTE]
wat car plate no.?
twin6869blogspotcom
