Need help
Anyone knows what these warning lights mean and the course of action needed. This is the 1st time encountered. Advice needed. Thanks!
Re: Need help
might be steering wheel sensor problem or dsc sensor.
send to workshop to check
Re: Need help
Javier Tan;985283 said:
Had similar error message except for The ABS signal. Sent to workshop and they said the sensor behind the steering wheel is faulty. This not go ahead to replace it as was quoted $900+ for parts and labour.
Re: Need help
Have encountered this before and was told that this could mean ABS failed or Flat Tyre Monitor failed...
You can continue to drive but please refrain from hard brakes.
Good luck
Re: Need help
ABS faulty warning.
Yes could be sensor problem but could be real ABS problem too so best to get it checked by a good workshop.
AnitaDeveau
