oil leak from vanos?
lesliek
hi, i recently realized that my engine was leaking eo but it wasn't the gasket as i just changed it recently.
according to the mech, its the 2 black clips that is at the front of the engine that is leaking.
anyone have any experience on this?
photo below:
Re: oil leak from vanos?
photo below:
if its the 4-cyl 320.
quite normal. expect more...
last time change gaskets all over. until nothing left to change.
used to take it down to one of our resident bimmer gurus - Rod (R2D) @ Woodlands - he'll sort you out.
Yes 4 pot 320i can you give me a ball park fig of how much the repair?
Can't rem. too many years ago... And prices might've shifted since.
So best just give your preferred BMW workshop, e.g. R2D in my case previously, a call.
It's not a fatal issue. But one of those many niggles you need to sort out.
Do keep an eye on the water hoses + radiator + overflow tank.
Good to do preventive maintenance on those. Else you'll get caught out when you least expect.
photo below:
Usually the O Ring leaks due the wear and tear. They are very cheap to replace ranging $3-5 for the smaller size ones. >$30 for the bigger size one like crank shaft oil seal
Thanks for your advice guys.
Went to JB WCA to diagnose and fix the issues.
Turns out:
oil cap leak
valvetronic seals leak
gasket flange leak
Total damage RM$330, downtime 1 hour
tk88betcomvn
