MapleLeaf;453889 said:I noticed that when the gear-stick is at 'P', the car wheels are locked already. Is there a need to pull handbrake on a level-floor car park?
I always pull the handbrake lightly only. Isn't this as good as not pulling the handbrake?
Because lock mechanism will wear off. It should be cause a bomb to repair it (correct me if i m wrong). Hand brake pad wear off? Cheap cheap to change.MapleLeaf;453889 said:I noticed that when the gear-stick is at 'P', the car wheels are locked already. Is there a need to pull handbrake on a level-floor car park?
Racebred;454062 said:P is stopping your car from moving by locking up your gears. Handbrake is by clamping your wheels (either by your brake disc or the inside of your hubs). The former is not very efficient if the car's heavy, slope's steep, or accidental buanging from another car, and may actually spoil the gears. But in an enclosed carpark where the lot is flat, and you're next to the wall, it really does not make much of a diff if you pull the handbrake or not.
but if some mischievous person keeps pushing and rocking your car on your lot, he'll eventually spoil your gear locking mechanism i guess, if your handbrake is not on.
Racebred;454320 said:yeah but if they continue pushing the car to a slope, then its byebye car. In many crowded cities around the world, esp in europe, and also in the early days of spore, many people do not pull their handbrake, and also leave their cars in neutral, so that during parallel parking, your car can be gently nudged away, when space is at a premium. As long as everyone in the city, like paris for eg, observes this SOP, it's pretty safe. but your bumper looks ugly. In spore, when you double park in the olden days, you leave the handbrake off so that the car you are blocking can push your car away when he wants to leave. But nowadays this SOP is forgotten liao. people just honk you until you run out, or stomp you.
Arg, so that's normal. I thought something wrong with my car....R2D;454341 said:When you park on a gradient, put to park, pull handbrake and release the foot brake, you tend to get a lurch. When you leave and get the car out of park, there will be a loud thud which is the entire transmission unloading.
Just to confirm, what you mean is that we should pull handbrake even when in P, right?R2D;454341 said:IMHO, Not recommended.
C3P0;454349 said:Arg, so that's normal. I thought something wrong with my car....
