probelm in cranking
tien1207
My E90 Pre-FL changed crank sensor, starter, spark plugs and ignition coil still have problems in cranking. need some advise. now everytime cranking and would like about 2 to 3 times to start up engine but it seems like v weak starting up.
Re: probelm in cranking
Have u check your battery voltage?
Whats the voltage during cranking?
ShaunJeremy;1079146 said:
Hmmm not sure if it's the same issue ... But my MINI had hpfp issues and was exhibiting cranking issues as well . Also found out that my valve cover was loose which contributed to the issue
so solved afterwhich?
Also, I'm not sure about the majority of owners ... But I tend to push the ignition button once first to start the electronics and get the pumps working ... After all those gizmo sounds stop then I'll start the engine.
Not sure if it's correlates to one of the steps to prevent cranking woes , but none of my rides had cranking issues except the MINI (which was pre-owned)
Your mini is cranky.... cause you treat your xiao err better.
Go diagnose the car and tell us whats the problem. It seems every parts are ok according to owner. Me so curious to know whats the problem
