This is not new of course, engine OIL COOLER; but something to consider for maximum protection for your engine against THE ENEMY - heat. Although BMW recommend a optimal engine oil temp, I don't think s'pore climate will provide anything that will be below its optimal temperture. If any at all, it wil be higher than optimium!!
This the following write up about the Kit:
"The kit is designed to be a bolt on component that is easily installed.
As oil is the lifeblood to your engine, keeping it cool will reduce viscosity breakdown and prevent premature wear. With the oil cooler kit this is accomplished by routing the engine oil from the standard oil filter housing to an externally mounted aluminum radiator mounted below the front bumper.
To prevent high pressure losses to the radiator, large inside diameter (.50 inch) stainless steel braided hoses are used. Anodized Aluminum aircraft style connectors are used to join the hoses at both ends. To prevent damage to surrounding rubber hoses, an abrasion resistant cover is used.
When it comes time to change your oil, no special filters are required as the kit uses a standard BMW filter.
Added protection to the radiator and hoses is achieved by having the engine oil filtered upon leaving the adapter cap. This is a small but important feature in the unforeseen event that an engine fails and sends metal particles into the oil pan, thus eliminating the added cost of replacing the radiator and oil lines."
Just wanna see feedback and exchange of ideas on this topic and at the same time inform bros about this existing product! I think is great and so far no compliants with bros from the US side. Since this isn't LTA's no no,(is it?) i think it's safe to talk about.
Attached are pics for viewing pleasure.
Note the simplicity of the whole setup! Cooler also come in matt black - perfect for blending in.
Wilman, you were saying you do bring in this product right?
YOU WILL DEFINATELY NEED THIS IF YOUR CAR RUNS LIKE THIS:
http://www.infinitas-gmbh.de/data/i...id=93&func=fileinfo&parent=folder&filecatid=4
or like this
http://www.blowne46.com/Videos/Mbenvosc120mph.MPG (NOTE THE MPH DIALS!)
or like this
