dkk
Hi folks,
Problem since endless. After i collected my ride - used E60-523i July 2007 (Mileage 76k km) below problems i have faced so far.
1. Fuel filter - seal broken and had it changed
2. Hand brake - 100% pulled and still can roll back. Had readjusted the rear brake but only improved abit.
3. Aircon - Sometime it gave a huge "Dong" sound and the whole car also jerk. After increasing the temperature, it back to normal. It happens on and off.
4. Psss sound - I could hear ppsss sound when i start off my ride. Dont know where it come from - Suspension? brake?
5. Front brake - Everything when i brake, i could hear loud metal sound.
Had went to mbm and BCC to check 3 times and all sounded OK.
Ex-owner service history;
1. 64,200km - Change ATF oil, filter, coolant, brake fluid, washer tank motor with bush, fluid in hydraulic brake system and coolant with anit freeze.
2. 68,160km - Front disc brake pad, discs and sensor
3. 71,347km - Replace brake caliper clip.
After i took over;
1. Full servicing @ 74,645km, change fuel filter.
2. 76,405km changed upper and lower arms.
I really dont know what to do next. Any kind folks can advice me?
After i took over;
