PZero vs. Rosso vs. Nero
gr8golf88
Wondering if anybody has any views or experience on these tyres or can help to interpret the info below?
The information below is taken from tirerack.com. Based on my limited knowledge and what I can comprehend from the extract, all 3 models are described in a slightly different ways, but they sound similar (e.g. got asymmetric tread design, a special silica compound, etc.)
The only difference that I can find is that the tread in the Rosso is supported by PenTec to provide more high-speed stability while reducing tire weight and temporary flatspotting when parked overnight.
So, which one is the best among the three?
PZero:
P Zero tires feature a special silica and carbon black tread compound that proves competent during the first few miles of driving when the tire is still cold, as well as consistent performance throughout the tire's life. The tread compound is molded into Pirelli's S-treme asymmetric design in which the location and width of the circumferential and lateral grooves minimize deformation to blend responsive handling, hydroplaning resistance and wet traction with dry road performance, even wear and acoustic comfort. Special nano-composites in the compound beneath the tread protect the carcass from deterioration and merge sport handling with ride comfort. The tire's internal structure includes twin steel belts reinforced by polyamide cord plies and an integration of nylon and aramid cord that controls tire profile deformation and stabilizes the tread area to enhance high-speed capability and handling.
Nero:
On the outside, the PZero Nero features a silica and carbon black enhanced tread compound molded into a subtle asymmetric, wide rib tread design to increase the rigidity of the tread to resist deformation and enhance grip and steering response on a variety of road surfaces while enhancing resistance to irregular wear and generating low noise levels. The tire's circumferential grooves are optimized in their position and width to maximize dry road performance while enhancing hydroplaningresistance. On the inside, the PZero Nero features twin steel belts reinforced by zero degree nylon to complement a lightweight aramid internal structure that resists deformation at high speeds.
Rosso:
Specific design techniques, raw materials and manufacturing methods have been incorporated to produce Pirelli's most comfortable Max Performance tires.
The PZero Rosso System includes both asymmetric and directional tread designs, each tuned to satisfy the unique performance needs of different types of vehicles and uses. The PZero Rosso Asimmetrico is the most widely used because it's designed for both front and rear axle positions of front engine front-wheel drive and rear-wheel drive cars (and on all cars driven on the track). The PZero Rosso Direzionale is designed to offer enhanced hydroplaning resistance and is primarily for use on the lighter load carrying front axle positions of mid-engine and rear-engine rear-wheel drive cars (which are then combined with the PZero Rosso Asimmetrico tires on the rear axle positions).
Both of the PZero Rosso tread patterns are elegant. The Asimmetrico tread pattern retains the "Zero concept" of earlier PZero tires by combining a semi-slick center rib that enhances driving precision while accelerating and braking with robust outer shoulder and intermediate tread blocks that are connected by circumferential "multi-ring" ribs to enhance dry grip. The independent blocks of the inner intermediate rib and inside shoulder are separated by wide grooves to help eject water to reduce hydroplaning and enhance wet grip. Considerable use has been made of curved grooves, which complement the circumferential grooves to reduce noise.
PZero Rosso tires use a silica-enhanced tread compound to provide better grip in low temperatures in the wet and lower rolling resistance in the dry. The tread is supported by PenTec (a material developed by Allied Signal for space exploration) cord which is used to reinforce lightweight steel belts and give more high-speed stability while reducing tire weight and temporary flatspotting when parked overnight.
Re: PZero vs. Rosso vs. Nero
are you going tracking route???
P zero best for wrong offset rims
best on my statistic.
P Zero is the best .( among the 3)
saw many supercar running on this tyre Lambo/audi R8/AMG
if it's just for daily drive and spirited driving once a while, the rosso/nero will be good enough.
i hv used rossos n zeros. the rossos r hyper fast wearing. 1 step below zeros. zeros r like ps2 grade. very very similar feel. same weight. but after 20k...gets noisier.
Thank you all for the insight. Appreciate it. Will give the zeros a try when it's time to replace the tyres.
I just replaced my 19" from F1 assy to P Zero.
Noisy wise is almost the same for both tyre.
P Zero steering feel is more direct than F1.
Also when going through those speed reducing strip the P zero is less bumpy than F1.
Only down side is 220 tread wear for P Zero and heard it wear out quite fast if compare to other like PS2 or F1.
I had used Rosso on my E46 before and the performer is a grade lower than F1 and P zero.
