Radio interference after installing DVR
eugenetan
Hi guys,
I just installed my Thinkware FXD900 front and rear camera. After installation, I realised that my radio reception got worse for some radio stations. Could it be the placement of my camera that is causing the interference? Or do you guys have any idea what might be a possible cause?
Anyway, I will contact the workshop that installed for me tomorrow to clarify.
Thanks! :)
Re: Radio interference after installing DVR
This is cause by the power interference from the camera.
Option
1. Dont use the rear camera
2. Re- locate the camera away from the middle. move slightly to the left or right
Its will help
Check for lose connections ..... Where the camera taps the power from ....
dont need to check for loose connector and power supply. doesnt matter with the antenna reception. just unplug the dvr power source and u will know. this is common mistake for most dvr installer. if you know where is the antenna booster located at then you will know what i mean...
thanks bros for your suggestions. i have already moved it to the left and the problem is solved! the issue used to be so bad till i could not even receive any reception in the CTE and KPE tunnels.
really do appreciate your help! :D
Not looking for the source ...its checking that the loose connection is creating emf .....
Is the problem resolved? One possibility is the interference from the rear camera which is sticker to the radio antenna
gemwinrestauranteclubcolo
