Recommend intake for 630?
878
Can anyone recommend a good air intake for 630 and point me in the right direction to get them? enquiring for a colleague. rather hard to find....
thanks!
Re: Recommend intake for 630?
Hey there, as far as i know for the 630 there are no air intake available in the market.
Been trying to find it for quite some time already. All are for 645 650 M6 none for 630 , only drop in K&N air filter is available. Do share info if you happen to find an air intake for 630 ^^
thanks!
:whythis:
Aiyo my dear brother!! U see me everyday but never ask me.......If cannot find a bolt on intake can try this.
1) Remove the air box,
2) Find a piece of thin cloth which can see thru a bit
3) Place it on the intake hose, used a wire to tighten it (make sure very tight, if fly off sand or whatsoever suck in...H.K liao)
Last time did that on my SIR wah lan a.... Power sia, dyno tested 8HP increased!!! Total cost $1.00 with $0.20 change. $0.10/HP very cheap. If on 3liter engine should have more... :lol2:
thanks!
For your info, there are several intake for 630,
Intake type= BMC by Espace, Cyberspeed by J4C
Drop-in type = K&N and Hurrcane by J4C
Cheerz!
i am using BMC...very happy with the result..
i know of a guy driving a 645 with BMC intake too... all are impressed with the result..
Y not go for a Gruppe Man? :)
Ah man shd be able to fabricate a intake pipe, with MAF sensor housing, etc.
thanks all for the feedback! will post outcome after installation!
RaptureM3;315893 said:
archie scare me i tot u buy 630.. haha
He pretend said for his friend la. The 330ci pass to his father liao la :)
BMC is ok so-so only. Had it fitted in another car when I was back in the States, dyno results showed no improvements though.
GruppeM does not have a Ram Air System for the 630i.
Drop in are the neater option. The others if you can fit in the stock airbox will be good as well. If I were you, I wouldn't go for an exposed pod. That just sucks up the engine bay aesthetics of the 6er.
Good luck!
Hi Terry, last time I wanted to fit the BMC on my 6 potter Ah wee from BVO told me not to cos many ppl complainting engine is not drawing enough air and have the intake removed. I was thinking is there diff model for the BMC? How is urs set up? Is there a hose conect from the stock ram air above the front grille to the intake of BMC? Or u had a hose go down to the bottom to draw in cold air?
im using a hose to connect to the stock ram air... at the front grille there...
i dont think its drawing less air because from butt feel...theres definetely a gain... and alot of people are happy with it... even a 645 installed it on the V8...no problem
But Terry, alot of people here know that your butt is too sensitive....after all that...ermmm...
pg88comim
