aproo;885638 said:I have an E92 LCI with Comfort Access and I was getting key fob battery low warning light. I replaced the existing battery with a new Energizer CR2032 but occasionally the light still comes on. Anyone experienced this?
Je_taime;993463 said:Digging up an old thread...
Anyone has a solution to this? Is it the sensor?
Anyway adding some info from googling:
- Key Fob with Comfort Access (CA) runs on non-rechargeable battery (CR2032)
- Rationale is probably to totally eliminate the need to take out the key and plug into the car
- CA equipped cars do not have the ability to charge the key, regardless of whether the key can be charged (I did not verify this with any technical pple)
okok...Red_Bean_Bun;993577 said:Happens once in a while when my pockets are full of other stuff .... once fob is out of my pocket warning goes off.
Je_taime;993841 said:okok...
somehow i am getting the warning EVERYTIME i start the car...
tried the following but still no diff:
- change new battery
- change new battery from diff brand
- hold the key in the cabin instead of leaving in pocket
how long did you drive? i tried 45min - 1hr but still no good...aproo;993844 said:Putting in the key fob while driving for an extended period of time solved it for me.
yes the other one is working fine...Red_Bean_Bun;993878 said:Use your other fob with new batteries and see how ......
