Replacing drive shafts
CSS
Would like to find out what are the symptoms of a worn or defective half-shaft (the shaft linking the final drive to the wheels). Is it a scratching, knocking or a clunking noise?
Are these parts prone to wear, I seldom hear people changing these drive shafts on the E46s?
I am trying to detect the source of some rear end noises.
Thanks very much.
Re: Replacing drive shafts
I also just changed my drive shaft not long ago ... you may want to call me @ 91073742 ...
Is yours an E46? My car done 40,000km and it's a knocking noise.
Wat would be a good time to call you?
Thanks
The drive shaft would be the one linking your rear differential to the wheels. Usually, they don't wear out. I have changed mine to a larger diameter for strength only! If you hear clunking noise, better have your rear differential check out instead. It may give way soon. And when they do, - have a tow truck ready.
CSS said:
Thanks very much.
