Review of Liqui Moly Oil - Post Track
satinGHOST|r!der
Legendary 10 Years
As you all know, we all have been using our trusted BMW Castrol oils for some time and I also thought of keeping my m3 to manufacturer's settings. I am a stock guy after all. :)
I was using Castrol TWS Motorsport oil that comes recommended from BMW for the M3. On the last track day, I was averaging 125 degrees oil temps after 4-5 laps of hard driving. It made me worry a little so I did some research on alternative oils. Then going in and out of Boss Motorsports I saw a big sticker with a WTCC car with Liqui Moly endorsed on it. I used to think that all these oil shit was some money making excercise as I never trusted other oils other than Mobil and Castrol. Aftermarket oils like OWS did not work well for me when I had the 335 and the oils ended up making the oil temps run slightly hotter. At least to me that was the case.
When I was shown the application guide to Liqui Moly stating that the e92 m3 had been tested and tried with this oil, i decided to try this oil with the CERATEC engine protection additive.
Yesterday on the way up to track, I consistently upshifted and downshifted many times to catch up with faster cars and even managed to get close to my top speed limit. Sustaining 200 over km/h for a good 3-4 mins and my oil temps were just slightly over 100 degrees about 105-106 degrees. Previously on short NS Runs, the oil temps were about 110 degrees and I am very sensitive to what goes around in my car and the normal temps I am used to see. So definitely a good benefit here. Also, the Castrol's I used tend to cool down much slower which is the best part about the Liqui Moly. I will talk more about this on track work below.
On Track, my oil temp gauge was in between 100 degrees and the 125 degrees marker. Meaning it was only about 120 degrees tops on the hardest laps. It did not even touch the 125 marker. On my last track day, the needle was spot on the 125 marker!! This is definitely such a difference as confirmed with other M3 drivers who were at the track yesterday. And I remembered I needed to do about 1.5 laps to bring it down to 110 degrees. When i cooled down yesterday, by the time i was at the back straights, the temps was down to 110 already. Less than a complete lap to cool down to a good level where you can start pushing the car again.
All in all, am very satisfied with the Liqui Moly and I will continue to use them indefinitely. This product really works and I have tested it quite extensively. :)
Hehehehehehhe....
Re: Review of Liqui Moly Oil - Post Track
Lol, looks like you had alot of fun with your car! :) poor gaskets !
how abt on TC car? Anyone have review?
should be 10W-60, it's amazing. you guys can get it done at 2Steer. Looks for Sha.
should be 10W-60, it's amazing. you guys can get it done at 2Steer. Look for Sha.
I had it on my CTR for the past 2 TD. Was on track for around 10-14laps and oil temp was only 110-115 deg (5W-50)..
Overall, it GOOD!!
Tks for the great review dude & for your continuing support for Boss Motorsports :)
We used Liqui Moly GT 10W60 on Omar's M3 with 2 bottles of Ceratec additive.
The Liqui Moly Oils really do bring the Oil Temps down. On my own 335 I find the oil temps on average a about 5-7 degrees lower when on track.
Come try it out.. we can be found at Unit 04-05 Sin Ming Autocare.
n u dun wanna do my car!
Omar Hiadee, how come u use 2 bottles of Ceratec and me only 1?
Anyway yr new exos very obscene....everywhere blue colour, like blue tape. Pls change. Ai sell mai?
i wanna do soon...
His engine big. Almost 8 litres of oil.
Just a heads up to trackies here that we also supply Liqui Moly Octane Boosters that are 100% petroleum based, and not using NMT like some other brands that can foul your plugs and cause your engine and elevate combustion temps.
Each bottle also comes supplied with a filler funnel so no more messing around with screwdrivers and satay sticks to pry open your filler cap.
I am 8 inches long so need 8 litres of oil. the other 2 inches is stimulants to make the 8 inches perform and flex machiam crouching dragon. :thumbsup:
used the octane booster last trackdy, my car cud rev higher...a good 300-400rpm to 7k redline....happy can liao.
You Da Man...Happy Can Liao
