Run Flat Tyre...the alternative
BMWM3
Bros there,
Any good place to change run flat tyre for 3 series?
PML cost...for 225 x 35 x 18 (front) $750 each (rear) $950 each.
Please advice. Thank u
Re: Run Flat Tyre...the alternative
I believed any tyre shop will be cheaper then this..
Just check for site sponsor, or Leong Seng in ubi etc..
Dont waste your money..
atec1267;830360 said:
Is it really cheaper at tyrepac? i check out the tyre for my X5 it turn out the same as the rest of the shop, the shop told me haven't add in labour, fill in nitrogen and ect. all in the same price as any other place.
some of their offers are ok; but yes, must factor in the installation costs - which is shop dependent, you can see the costs at the site. if you friend friend a particular shop, they may give your bro price.
BMWM3;830285 said:
Bros there,
Are those price nett or before GST? Maybe even higher if before GST..... without 'friend friend', other workshops/tyreshops that carries RFT should be cheaper than PML, I am pretty sure of that. Alternatively Tyrepac as some suggested.
Recently the price I paid for 215/40/R18 and 245/35/R18 (4 tyres total) RE050A with installation & GST, still cost less than 2 of the tyres quoted above, combined.
Was sure PML will be more expensive than other tyreshops but didn't know the price can be soooo :screwedu:
When deciding which 2 short listed trye brand/model, I will usually sources around and later get up to 6 different quotes from tyreshop (authorised dealership) or online stores or forum dealers before I make a commitment to buy brand/model I have decided.
Anyone can recommend a tyre shop for Run Flats?
Right now I am considering Tyrepac. They have listed Bridgestone and Continental, which if you factor in the GST and install cost, it will cost about $220 each. It's still cheaper than the Hankooks Run flats i am using now. Hankook used to be cheaper and I could get like $820 for a set, but the price has since gone up to $920.
Anyone knows where I can get Run Flats for about $200 each? I am looking for 205/55R16
Regards
Eric
Hi Eric,
Just curious - although your post was sometime back. So what tyres you finally changed to and how much was it?
Regards
Eric
I got my replacements from tyre queen, price of 4 almost similar to the price of 1 piece :)
