Side Mirror (left) run-out of proportion (outward)
Chye
Hi Bro,
RE: Side Mirror (left) run-out of proportion (outward)
Does anyone can advise how to adjust it back?
Or is there a place that can fit it at reasonably price.
Thanks!
Chye
Re: Side Mirror (left) run-out of proportion (outward)
no way to do it, time to buy new mirror side 500++ per side I just did mine.
The whole assemble goes outwards or just the mirror ?
The whole assemble, as in when you unfold it, it when out a bit more. (slightly out from the base holder)
same thing happened to me but i unplugged the wires on the left side, hence the mirror is now dead - doesnt autofold but that solves the problem of it overfolding.
however, if you get it fixed, can pm me the price and location? Thanks!
Try this ?
SUBJECT
Power Fold Mirror Position Incorrect
MODEL
E60, E61 (5 Series) equipped with power fold mirrors
E63, E64 (6 Series) equipped with power fold mirrors
E82, E88 (1 Series) equipped with power fold mirrors
E85, E86, E89 (Z4) equipped with power fold mirrors
E90, E91, E92, E93 (3 Series) equipped with power fold mirrors
F01, F02 (7 Series)
SITUATION
One or both mirrors appear to have folded out further than the standard position. The incorrect position of the mirror housing is typically not visually noticeable and as such, the customer typically states that the mirror glass is not in the stored position.
Folding the mirror in and out does not restore the correct mirror housing position.
CAUSE
The mirror has shifted outward from its standard home position. The new position is now stored as the home position.
CORRECTION
Do not replace any parts.
Reset the mirror home position using the following procedure.
PROCEDURE
1. Fold the mirror in using the power fold button on the door switch block.
2. Grasp the folding part of the mirror and fold it outward manually. The mirror housing will disengage from the mirror base and will now be in the breakaway position.
3. Operate the mirror via the power fold button. The mirror will now fold out past the expected end stop.
4. Operate the mirror via the power fold button again to fold the mirror in. When the mirror is fully folded in, the motor will continue to run until a clicking and/or popping sound is heard. This sound is the mirror housing resetting its position.
5. Fold the mirror back out, using the power fold button to ensure it has folded out to the correct position.
Hi Kelvin,
My workshop at sin ming say it can be done by changing the gear inside the mirror and will cost about $100+.
Let me know if you wish to go there for repair.
I will do it during my next servicing.
If side mirror memory tends to run off after unfolding, your workshop able to solve?
Yes, the owner's workshop say it can be done but I have not get it done yet.
Can PM workshop contact?
Look for Beng Wah at 97394116 at Sin Ming AutoCare Technic.
webgamehi88top
