Speedo Lights
Re: Speedo Lights
You really should read the manual.
Instrument lighting
You can adjust the brightness of the instrument lighting only when the parking lamps or the low beams are switched on.
1. Lightly push button 1 up or down repeatedly until the appropriate symbol appears in the display, accompanied by the brightness and the word "SET".
2. Press button 2.
3. Lightly push button 1 up or down to select the brightness; the setting is stored immediately.
4. Press button 2 in the turn indicator stalk.
The display again shows the outside temperature and the time.
Re: Speedo Lights
Err..thanks bro. But i found out yesterday night, that the adjustment "lever"is beside my headlight switch and i just run it up to make the speedo lights brighter.
But thanks for your feedback.
