Hi, anyone knows where to get our rims cleaned up? my 19" Breyton GTS is covered with brake dust and grime. I tried using the wheel cleaner but still cant get everything off. any ways to clean it or workshops that do offer this service?
sonax is good. but for first time cleaning after a long while you may finish the whole bottle in one session. just a small tip. for those areas/corners which the cleaner can't remove after spraying, tear some serviettes and soak in the wheel cleaning solution and then stick onto the area to let it do its work. it will also help if you use a toothbrush to lightly scrub on the black spots.
