I previously used goodridge for my track car. I wanted the custom terminations and connectors than the cut and paste ones that may leak due to the pressure.
Installed on all my vehicles from motorcycles to cars to bicycles. You will be able to feel the difference immediately with motorcycles and bicycles with a improvement in firmness. These vehicles are direct master cylinder with no brake booster so the firmness improvement is immediately obvious. For cars, it depends on how sensitive you are as there are a lot of flex in the system and the floating calipers are not that stiff to begin with. The brake booster will also mask the 'feel' upgrade that you should get from a stiff ssbh.
That said, its not a must but at the price of around $120-$150/pair for front or rear, its probably a simple upgrade that will definitely improve things at a cost that is affordable enough to not make you lose sleep over if the money is well spent.
if so good, BMW why no hab? BMW engineers develop and test their cars for like 5 years before a new model comes to the market. Additionally, each LCI model is further improved. Am sure their engineers would have considered this before.
to make money ... got option for m perf brake ... hehe
The brand is Goodridge... Goodrich is a wallpaper company or BF Goodrich is a tyre company..... Can try HEL as well. Stainless steel fittings compared to zinc plated fittings on Goodridge
Paiseh ..... I NTC2 only so my England no good .....
Haha!
SSbh is a good upgrade for the pedal feel. When u step it would not feel mushy.
However if you are regularly maintaining car n change your normal brake hose then this is not necessary as normal hose is make of rubber n this in long run expands under heavy braking n heat.
That is one of the reason I thinking to change... cos my ride is second hand and 6 yrs old liao... dun know how is the actual condition..
some more I always travel in MY...
Personally I prefer stainless STUNT or stainless KOPE but yes, stainless STEEL is better for corrosion resistance but there will be zero difference in performance compared to zinc plated fittings.
