Swap rear axel differential for Pre-FL E90 320
dutch
hi all, I have this winding sound... my mechanical says its rear axel differential.
Call out to all if there are bro/ sis going to trade in or scrap their rides, I would like to swap with your good axel.
Please call or sms me 98489175. Definitely going make it worth your time. thanks.
Re: Swap rear axel differential for Pre-FL E90 320
You can purchase the rear differential from the car scrap company in Singapore, no idea on the cost, you can text me on the name that I know on 97895067, the rear diff of E90 320i listed on BMW brochre is 3.64 Final Drive ratio, E90 316i installed similar ratio. other model will have different ratio 325i(3.23 ratio), 335i(3.15 ratio), installing a less number of ratio will affect the speedo reading and aceleration, top speed of the car.
For example installing a 325i with 3.23 ratio will result in slower aceleration, higher actual speed than display on speedo meter(potential speeding ticket)
my friend bought brand new from PML for 3k and installed at outside workshop.Total spending about 3.5 k.If buy a used one from propel about 1k plus .what if use 6 months later start to have winding sound also jialat.
3K? Go buy LSD liao.
changing the final drive ratio will affect acceleration and top speed.
Will not affect actual speed readings.......
Did you changed your axle fluid ?
many pple did not change ...
bro, i have a contact for a reliable malaysian workshop (boss ex PML) that i have swapped out for a very good price. Used to be troubled by the rear differenetial.
You can sms me @ 90619515
How were you troubled by your rear differentials ?
bet69help
