emiffy
Calling all suspension gurus...
saw this on the UUC website on FAQs on sway bars:
What about the rear bar?
A common misconception is that the increase in rear bar stiffness alone is the sole cause for bent (or broken) rear sway bar tabs (the tabs which mount the sway bar bushings). In fact, even under race conditions, most racecars do not break the tabs. Rather, rear sway bar tabs bend (or break) because of daily obstacles such as potholes, construction, and other road hazards. It is the sharp transition and weight shift in such conditions which will weaken and stress the factory tabs. In the events that the tabs do break, they are built into the rear subframe of the vehicle, which becomes a costly replacement.
So, my question is: given that we can't avoid potholes, constuction, road hazards, will changing to a thicker sway bar accelerate the failure of the rear sway bar tabs?
The last sentence is especially scary: rear subframe, costly replacement. Anyone ever had to change that before?
Thanks...
Thanks...
