This is how you can tell whether your N20 20i/28i engine is 10:1 or 11:1 compression
Slow_poke_driver
May have already been discussed before...
This is how you can check if your n20 engine is 10:1 or 11:1 compression ratio. i.e. this will end the debate of what engine is in what car.
Generally, 320i/520i should have 11:1. x1 z4 x3 should have 10:1 whether yours is 184ps or 245ps engine.
BUT HOW CAN YOU CONFIRM WHAT YOU HAVE?
Just go LTA website:
https://vrl.lta.gov.sg/lta/vrl/action/pubfunc?ID=EnquireTransferFee
Type in your number plate and key in any date. Don't worry, your car will not be transferred to anyone.
Then from there, check your engine code:
__________________________________
If you see N20B20A= 10:1 compression ratio. Here it is the 528i.
If you see N20B20B= 11:1 compression ratio. Here it is the 520i.
If you see N20B20C or N20B20D, you may have an engine that is made in china. Nonetheless, C is 10:1, D is 11:1.
Re: This is how you can tell whether your N20 20i/28i engine is 10:1 or 11:1 compress
My x1 20i is N20B20A. So yes, 10:1 compression then.
Interesting...
Interesting...
n20B20A shld be 28i right?
You shud read the above again....
Interesting. X1 having lower compression. Higher boost?
Usually that's the case. So Meek got bigger turbo. Can chip up like siao.
Meek's turbo already chipped up. If i see her on the road I will give way immediately.....
You so clever ne.... shhhh.... i forgot to tell you its potato chipped! Heeeee....
gemwinrestauranteclubcolo
