Tire pressure for 205/55/16
C3P0
Hi fellow forummers with e90 320,
Can I confirm with you that the recommended tire pressure (per door sticker), for 205/55/16 tires, is 280 rear, 230 front? Many thanks in advance for help.
Re: Tire pressure for 205/55/16
not upgrading to bigger wheels???
Double post.
iScoupe;672902 said:
pump 240 but depends on your offset.
U se-ri-ous?
Not my car le. U help me see your sticker can?
depends what brand of rubber.......
Japan brand thinner but might torn easily. If durexcan pump up to 280 times still like new.
Iike new for what... unless it is meant to be reuseable.
It would have been more meaningful it it's biodegradable.
Is important if u 搞事诽(四飞) . Before u hit last one must still like brand new. No time to change.
pump 300 front and back.
urs not staggered so no need to have different value.
as for why 300, coz is free, so pump more.
slk69 say... 0.03mm....... sibeh shiok.....
hitmee;673127 said:
slk60 kkj small...suit him
Careful what you say about slk69 because Human will tulan you. They dating now
I have a feeling this thread up lorry.
Got hold hands??? :lol2::lol2::lol2:
knn la... u want BMW tyre pressure or lorry tyre pressure.. if want ask pls ask properly.
think we so free to come help. :furious:
i think 34 psi all round will be good.
should not be so high for normal drivng condition.
please read the figures carefully, correct me if i am wrong.
for your 205/55/16 tyre with normal load and speed should be front 2.0 bar and back 2.2 bar.
your numbers are propably for heavily load and high speed driving.
2.0 bar = 200 KPA
you can change to air pressure slightly from Car maker recommendation but in mind to follow the pattern like your case back wheel is always higher
2.0 bar = 200 KPA
Thanks Robert. In that case I will tell my friend to pump 220R/200F.
My sticker could be diff from that of a 320....
