R335;598225 said:my label showing 270/300 for 18" if i remember correctly.
Somehow i find it too high .... ever tried of 250/270 n feel the ride very bumpy....
now pumping at 235/250 for 19".... still monitoring....
Check ur owner manual. If don't have, i have another more complicated way.tomace;598222 said:Hi all,
May I know how much pressure you all pump for your rubbers?
Not sure which one to follow..panel stated front 240 rear 270 = correct? :roll:
My rubbers setup are: (RFT)
Front 235/40/R18
Rear 255/35/R18
Thank you very much ~![]()
davidtch;598232 said:Check ur owner manual. If don't have, i have another more complicated way.
That's should be it. Do take note whether it is full load or partial load. It clearly indicate on the sticker.tomace;598234 said:Hi, thanks for sharing.
Didnt see it inside e manual book but on driver side panel, it indicate some pressure to go for.
So can i just follow e guideline stated??
Eg:
Front 235/40/R18 = 240
Rear 255/35/R18 = 270
davidtch;598259 said:That's should be it. Do take note whether it is full load or partial load. It clearly indicate on the sticker.
Full load = Always carry ppl around.
tomace said:Btw, Anyone on this set of rims? Thanks..
kenntona;598271 said:That's the BBS FI !!! $12K a set !!!
dcs2k;598294 said:no rubber i rem and only fits M3
dcs2k;598303 said:take a look at BBS RE-V, i got that in the end
Ahbengdriver;600932 said:Bear in mind as u drive the tyre heats up and 240>>250.
I only pump 220/230 these days. Back side very comfy....
