Re: Torque vs. HP
Racebred;168204 said:
so, what are the difference when we shift gears at peak torque vs peak hp, in a general petrol car. (meaning, performance wise is it better to shift at somewhere like 5000rpm vs 7000rpm?)
If you shift at peak torque or a little after peak torque to try and maximize area under the torque curve, then you end up with highest average crank torque, but when you factor in the gear ratios, your average wheel torque is lower (based on average petrol engine torque/power curves and average gearing gaps) so acceleration is not optimized.
If you shift beyond peak power or at redline in situations where peak power is close to redline, or where power does not fall sharply off beyond peak power, then you maximize area under the power curve and you have the highest average wheel torque. Acceleration is optimized.
You can work the shift points by power based or force based calculations and both in the end are the same, just mathematically different. You can also do it graphically by looking at power curves and knowing gearing gaps, maximize area under the power curve. The general rule though,
and almost without exception with modern petrol otto cycle engines, is to shift at redline to maximize acceleration. This is just due to the shape of the curves and the gearing gaps.
CVT requires different strategy but we can leave that out since the system isn't perfected yet and not widely used, and also because the electronics do all the ratio changing automatically and the driver is no longer involved in shifting.
TripleM;168211 said:
Hard to say really but I suppose the optimum shift RPM will probably be different for each gear.
This is true, but often the ideal shift point is past redline. Often we run into redline before we would like to shift, and longevity taking precedence, we are forced to shift at redline.
I guess there's a myth out there that changing gears at redline get the best acceleration of the car.
It's not a myth, in fact it is almost a rule with modern petrol engines - especially so with sportier engines.
There are very few modern exceptions to this rule. For every 1 example to the contrary that is found, another 10 can be found in support of it. Pick any production car, with dyno chart, whose gear ratios are published, and it can be shown mathematically.
AC Schnitzer;168223 said:
HP is how fast the car hits the wall.
Torque is how far you take the wall with you.
This has little to do with hp and torque and much more to do with mass, speed, frontal area, chassis strength.
As for 4th, 5th or 6th (if 6MT), shift at where your torque curve starts to drop or when the boost tapers down.
Unless the torque fall off is very sharp, there is no reason to shift early. If it is unclear, it is easy enough to calculate the shift point.
Best thing to do is to do a dyno and study your hp and torque curves along with AFR map. If you are using Dyno Dynamics, make sure that you specifically request for "Shoot Out Mode". If your car is dynoed without shoot out mode, the hp figures can be manipulated. Easy to trick noobs into believing they had gained 50hp when in reality they achieved none. Shoot out mode by itself cost $1500 just for the licence alone.
What's important is the shape of the curves. It doesn't matter as much what the actual value is talking strictly in terms of determining shift points. As long as the curves are proportional and accurate, it doesn't matter if they are translated up or down along the Y axis.
goggomobil;168227 said:
Unless your engine has an unusual power curve, for max acceleration I think best to shift so that RPM falls to max torque point after you shift up, and this will depend on your gear ratios and how they are spaced.
Disagree. If you're doing force based calculation then you have to look not only at resulting crank torque after shift, but consider the new gear ratio you're now in as well to arrive at wheel torque.
It is very common not even to see peak torque RPM on an engine driven for performance - especially racing engines. And racing engines are engines that generally have torque peak closer to power peak, which underlines the point about how maximizing area under the power curve and shifting at redline is as close to a rule as you'll get to in shift point selection, and not shifting at peak torque, or shortly after peak torque.
I think it is easier to work a real example than to get lost in the fog. I'm sure you'll find most cars favour shifting at redline. Pick a production car that has lots of data published on it and crunch your numbers.... you'll see..
