tpms
sockster
are there tpms sensors in the stock 16" rims of e90 lci?
planning to change rims and keep my stock set so i need to know if i have to purchase another set of tpms
Re: tpms
None of the stock rims has TPMS. It uses ABS sensor to check whether there is any puncture via difference in rotation btw wheels.
Re: tpms
all TPMS comes standard on all wheels from BMW, at least in the US, its like this
Re: tpms
Only US-spec cars have TPMS. Europe and Asian specs, no TPMS.
Re: tpms
I installed my own at - 2X0++. There's another one from another bro in the forum. Kind of good to have. Very helpful sometimes because you don't have to guess the pressure ....
Re: tpms
TPMS is different from run flat indicator, right? Any kind soul care to explain to me how tpms works? thx.
Re: tpms
For the add ons like mine, it has a separate display with 4 tire pressure readings as well as Temperature of the individual wheels. It also has alarm for low PSI reading or temperature.
OEM Run flat just tells you "a" tire is lower but you need to check which tire is it by looking at it. Not easy when I checked.
Re: tpms
Put simply, TPMS detects individual tyre pressure. Run flat indicator detects loss of tyre pressure by consistently comparing wheel speed and revolutions with the help of the signal from the ABS system.
This means that in the extreme case of 4 leaking tyres, TPMS (all 4) would have alerted you, but not RFI.
Re: tpms
OK thanks..understand now. Got a little confused searching the net cos our RFI is also known as "Indirect TPMS", as opposed to Direct TPMS which u guys are referring to..
