..with 1 being completely wrong, and 10 being completely correct, how do the following score in your opinion, assuming the aim is to drive the car well, and drive the track well:
1) T4 Sepang, you are supposed to brake hard a couple hundred millsec just before turn entry. The steering wheel input for this turn entry is supposed to be from 0 to ~170 degrees of steering wheel input in under a couple hundred millisec - nearly a step input
2) T5 and T6 of Sepang being described as "flat out acceleration corners".
The car in this case in a typical showroom stock road car, ~1.5 tons, street tires, ~220hp, RWD.
Just curious as to what most trackers think of the above.. thanks.
