Transmission oil for e46
AdrianNg
Hi
After reading all the threads regards to "lifetime" not "lifetime" for teh transmission oil, i drew the conclusion that it might be a good idea to change it at ~60Km mark.
I have called one of the garage and was quoted ~S$350 to flush the transmission oil, change the transmission oil filter ( never knwo that there is one ) plus the rear axle oil.
my ride is a e46 1.8 pre-facelift and current clocking ~62km
Any comments if this is a fair price ?
Adrian
Re: Transmission oil for e46
AdrianNg said:
Hi
Adrian
Quote seems a bit high. I recall having my transmission oil and rear axle oil changed (including flushing) for around S$250.
Hi Yuin
Did you change the transmission oil filter ? care to share with me where you change yours and at what mileage ?
Adrian
Hi Adrian,
Yup. Filter is normally replaced when oil is changed. Did mine a bit late, at 88k. Serviced at Juzz 4 Cars.
Yuin
AdrianNg said:
Hi Yuin
Adrian
I suggest that u go back to PML if u die die must change, if not ... anything happens to ur gearbox then prepare to come out another 8k for ur 1.8L. Think bout it first... dun actually need to chnage ATF.
great ...now u given me another perspective
so the question is still back to square one... " to change or not to change and that is the question "
any bro care to comment ?
Adrian
Adrian
My humble opinion is not to ... dun need.
the question is whether you need or need not.
if you need ... like i said .. go back PML .
