TuneKit Power Pedal
JuzzforCars
Introducing the TuneKit Power Pedal.
Optimised throttle characteristics
to improve engine response
With one simple original plug in connection at the throttle pedal that directly changes the parameters of the original throttle to improve throttle response. All control systems work within the original values of the vehicles manufacturer.
OVERVIEW OF THE MAIN BENEFITS
Fits almost all cars with electronic throttle position sensor
For information about availabiltiy browse our vehicle pool
Optimised throttle response
with adaption of the throttle parameters in real-time
Quick and easy installation
with original plug-in system at the throttle position sensor
Safety First
Tested and refined to comply with international road safety requirements and comes with a three year warranty
Adjustable on sensitivity. :)
Re: TuneKit Power Pedal
hey seetoh
what's the diff between this and sprint booster?
So tell me... Will this stack with the Sprint Booster?
Power !! Mwhahahahahahaha.
So will this perform better than the reputable Sprint Booster or not.
can adjust until i step than my car leaps like M5?
Why wouldnt it? In fact probably better as its adjustable.
bump
Had the sprint booster before. Basically it just gives you a more aggressive throttle response. Peak power/Torque is the same. No theoretical increase in power. But butt feel may feel like it as car is hyper sensitive. But make sure ur wife is ok with the setting esp for this one. Heard for the older sprintbooster, that some of us forummers wife cant get used to it than when reversing bang the wall. HEhehehe...So be careful when u pass the car to others if u are sharing the car.
hmm, this problem can be solved with the Tunekit power pedal b'coz sensitivity can be adjusted.
Can we adjust sensitivity after its installed or do we have to dismantle to adjust again?
When tuned to most sensitive settings, will it be more sensitive than sprint booster?
We need answers Seetoh!! :X
jinooi;347396 said:
hey seetoh
Hey hey...
The diff is the power delivery of the PP is a lot smoother and it is adjustable on the sensitivity, like if too jerky - u can tune it down, not enough u can tune it up.
According to all the drivers who have fitted the PP on, the feedback is : much better response when compared to SB.
Aiyo... give me some time mah... just had lunch nia leh. :(
Yes, you can adjust the sensitivity on your own by turning the knob with a test pen. Just flip the cover and u see the knob liao. Just that u cannot adjust while driving that's all. SAFETY FIRST!
If u tune to max, the power is much stronger than SB.
:lol2:
Hi Seetoh,
I assumed that it is compatible with all e-throttle cars like the Sprint Booster? Can you PM me the price too?
Thanks.
grappleking88;348668 said:
Hi Seetoh,
Thanks.
Yes, for all e-throttle BMWs & Minis. :)
Seetoh...
You poisoned me already...
PM/SMS me the total dmg pls. Evil boy.
vin7777comco
