Tyre sidewall cut
OldMasterQ
Advise from :
Tyre shop A - looks okay, it didnt hit the nylon cover, can use super blue, but it will tear if do hard corner, if always drive at high speed, better change.
Tyre shop B - no need change l, use super glue..
Sifu A : who bite? no need change tyre, try glue it back.
Sifu B : no need change, but if you got money then change lo...
And I super glue it.......
Re: Tyre sidewall cut
Have a Good Cornering weakend.......................
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers[/QUOTE]
but it is the metal kerb corner the tyre...............:furious:
dark skies;979398 said:
A sudden bump on then road might caused it to burst?
shouldnt be unless something hit on this weaken spot...
I dare not confirm this, better let those with deep understand of tyre to comment...
Yah.... Will be more likely if there is a weakened spot... Let the expert speak? But I guess it's always better to be safe than sorry
I remembered someone told me that dump truck tyres are sent to re-tread. I think they are likely to be glued with new tyre tread. Maybe you can look along this. If there is tyre re-tread workshop in sg and ask them their opinions or help.
change all 4 tyres..........safer...
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeerd
Wah.. Must change rim also and redo alignment, balancing....
Otherwise will affect FC
dont forget...........HIGH speed balance tooooooooooo
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
Kns you salted my wound....
Please cut your hair and take sleeping pill....
bet69help
