What's the correct tyre pressure?
titanic
I am getting a tyre puncture error message but it is obvious to me that none of the tyres are punctured. I suspect that tyre pressure maybe too low. What is the correct tyre pressure for front 245/40R18 and back 275/35/R18? I am not sure which is the correct set of figures.
Re: What's the correct tyre pressure?
hi there,
open your driver's door. there should be a white or silver sticker down low, near the kick plates. check for your tire sizes.. there should be the readings for the correct pressures. :)
** this should work for stock wheels, or wheels within the standard size range for e60s. for plus sizes or aftermarket applications, you might need a higher or lower pressure as compared to stock.
cheers,
saify.
usually it should be around the 235KPA region ..
usually its higher on the "driven" wheels - rears on BMWs
maybe its really a tyres punctured.
i got tyre punctured error on the idrive screen for 2 days. didnt believe its really a tyres air leaked. but drove to stamford to check and confirm there is a puncture.
245kpa front
265kpa rear swee2x...
nagad88asia
