Wheel Alignment
Re: Wheel Alignment
Front camber sounds right with 15'' of neg camber. Did they install aftermkt offset key (bolt) to tune back the front camber? Rear camber is probably not adjustable and -2 deg is excessive IMO for street use unless you are going for auto-x. You can compensate with more toe-in at the rear.....
Re: Wheel Alignment
If your ride is E36 or E46
Front you cant do much as it is fixed only to adjust your toe
As per rear mine is (left) -0.13 (right) -0.15
Sad to say -0.2 is too much
rr88vipme
