When to change spark plugs and what is recommended?
OYG
Hi guys,
My E90/320 is close to 3 years at 76000km. When should I change the spark plugs? What plugs are recommended? Learned from the forum that some of you used ND Iridium while others use NGK or stock plugs, etc.
Any advice will be much appreciated, thanks!
Re: When to change spark plugs and what is recommended?
Speak to R2d on this forum
stick with NGKs it is time to change although rated for 100000km Singapore traffic is no good for the clean burn....
Hi desertfox65, I have just bought 4 Bosch Platinum plugs from Eng Soon although they said both NGK Iridium and Bosch Plastimum are stock plugs for E90/320. Can I use the Bosch Platinum plugs? I intend to change plugs every 70 - 80k since they are not that expensive.
Here is the part numbers for both bosch and NGK suitable for the E90, 320i
03Spark plug, High PowerNGK IZFR6H114
12120032134$18.41
03Spark plug, High PowerBOSCH FR7KPP3324
12120032135$18.41
hope this helps you..Ignore hte price as it the US$....
cheers.
I recommend Bosch IR fusion SPs (you can buy it from MXtrading). Just changed my Denso IR to the Bosch, can feel an immediate improvement in performance. :)
Ahbengdriver;434381 said:
BRISK for E9X ?
Saw that there are Brisk plugs for the 135/335 at J4C.... Wanna try?
U try first. U be guinea pig :goodup:
12120032134$18.41
12120032135$18.41
cheers.
Hi, thanks very much for sharing :)
Hi bro desertfox65,
Can I have the spark plugs changed at any neighbourhood workshops? Do I need to reset the ECU after changing the spark plugs? Thanks!
no need to reset ecu suggest u go to one of the recommended workshops in this forum
Hi bro desertfox65, done at BVO liao! Thanks!
Hi OYG,
Did you feel the engine more perky after the spark plug change?
My car have clocked more than 60k and i feel that its performance is not so good anymore.
BTW, what plug you use?
Regards
Jason
At 60K you may need to get the MAF cleaned as well ;replacing spark plug alone will not give you a very big change in performance.
oh, i see.
thanks
which workshop can do a proper MAP cleaning? mine's has more than 100k on it and i have not gone its MAF cleaned.
any of the recommended workshops can do that.
Usually they spray with cleaner or similar. Unless you are familair, do not DIY or you may damage it.
I also need to change sparks soon also.
If Rod's mod does temp me enough, i might just go that direction rather then using back the stock plugs.
