White smoke coming from exhaust.
Re: White smoke coming from exhaust.
likely valve cover gasket. half day job and repair cost is nearing $1000
Send to workshop.
I doubt anyone will be able diagnose much less solve your problem based on the comment that there is white smoke coming out from exhaust.
Googled the following: What Does the Smoke from My Exhaust Mean? » AutoGuide.com News
What does WHITE smoke from my exhaust mean?
White smoke can be nothing to be concerned about if it’s thin, like vapor. This is probably the result of normal condensation buildup inside the exhaust system. This kind of smoke disappears quickly.
However, thicker smoke is a big problem, and can be caused the engine burning coolant. This can be the result of a serious issue like a blown head gasket, a damaged cylinder head, or a cracked engine block – all of which are costly repairs.
Don’t ignore it, however, as the problem could become far worse. Even a small leak in the coolant can lead to overheating and serious risk of damage to the engine. A coolant leak can also mix with oil and cause serious headaches for you and your car
If it's white smoke, and only during the morning startup, it could be water vapour in the exhaust. Not an issue. If even after a few minutes of starting and still persist, then may signify something worst.
miso88bar
