WTB: Recon or OEM Air con cooling coil for E90 335i
Wh0cArEs
Does anyone know of any lobangs or workshop which carry the above? A new one costs a bomb and I'm sourcing for cheaper alternatives.
Thanks!
Re: WTB: Recon or OEM Air con cooling coil for E90 335i
I fixed mine aprox 1000 with workmanship recently, + - around this range.
Provide this Info for ur reference.
Yup... i got quoted ard that price.
Anyone else who can help?
If you want to do it in JB, it will be cheaper.....
For Recon Compressor.... Parts + Labour +gas = RM1500 Only
New Compressor Parts + Labour + Gas = RM2800 Only...
Current Market Price in JB....... Interested PM me and i can bring you there....
Suggest you buy a new set instead of recon.
Based on my understanding, the bulk of the cost goes to workmanship as it is very tedious to dismantle the whole dash board
What is the mileage of your cars when the aircon needed attention?
tks for the tip, will think abt it :)
my car recently had a new cooling coil replaced at BOSS
will PM u the price inclusive of labour and its really quite a bomb !
In replacing the a/c compressor, you may want to consider changing the a/c coil at the same time. The replacement either of the two, there is a need to remove the dashboard and this goes to lots of work and high labour charges.
Replace a/c compressor no need to remove dashboard..only the cooling coil you need to. Strongly discourage replacing old cooling coil..its not worth it.
I did mine last time in JB. After that I heard the cost go up.
Now I pray that my aircon coil doesn't kaput. Otherwise, faint.
In Singapore, try Motoair. Just google for it, it's located near BVO/Yew Lip.
Wonder how u can drive to JB without air-con...must be having a sauna inside,,,
Btw must change the valves while changing cooling coil....
Valve is not expensive thing and why not do it together.....
Come in with window open loh..... in the early morning.... not so hot....
So for the benefit of all.
Whats the cost of replacing the cooling coil (OEM) + expansion valve + labour in JB?
I posted in page 1 on the pricing.....
Just bring along your golf set and play golf while waiting.... Austin Country club is nearby...
I beleive your compressor is refering to cooling coil or both???? You dont change air-cond compressor if its not faulty.
Received with thanks :)
Yup, dat's the mkt rate. Some cheaper bcoz no GST :laughlik:
slotgacor88507
