WTS Aluminum Engine Oil Sump/Oil Pan For F20, F30, F34, F07, F10, X1(E84), Z4(E89) models using N20/N26 engine.
Kasila
Selling BMW Aluminum Engine Oil Sump/Oil Pan For
F07, F22, F23, F30, F32, F33, F34, F10, X1(E84), Z4(E89) models using N20/N26 engine.
This is an improved aftermarket Oil Sump/Oil Pan made with Aluminum to replace the original Plastic Oil Sump/Oil Pan.
The original assembly uses plastic Oil Sump/Oil Pan with gasket which were not lasting and able to withstand high temperature, be it warping of Oil Sump/Oil Pan or gasket issues, which causes oil leak after 1 or 2 years of usage. This is very common problem for BMW.
This improved development is used together with a high temperature, solvent-free, permanently elastic, fast-hardening silicon sealant, without the need of using gasket. This solves future oil leak problem at the oil sump.
Includes
-Aluminum Engine Oil Sump/Oil Pan
-A tube of Original Victor Reinzosil silicon sealant
Cash & Carry.
Carousell: https://www.carousell.sg/p/bmw-alum...rer_request_id=rRBAVDrGzfcyu3I-&t-tap_index=1
ae888ong236
