WTS: E90 325 Brake Set
fishmonger
Hi Guys,
I am looking to sell my brake set coming off my E90 325.
Front Only: $320.
Front & Back: $520.
Not selling back brakes by itself.
Good for bros requiring replacement, dekitting etc.
Thanks.
* Brakes have been sold to a gentleman. Thank you for the interests and SMSs. **SOLD**.
Ken
Re: WTS: E90 325 Brake Set
Its about the same as 320 brake set. Rotors are 12mm bigger than 320 (300mm)
Correct me if im wrong.
Bumpz for seller ~~~ :)
I believe rotor size 312mm is for 323.
For 325, rotor size should be 330mm.
Bump for the seller.:)
Hi
Pls forgive the ignorance. I am driving a 320 with standard spec. Would upgrading the brakes give make the brakes more effective. If so by how much? I suppose we cannot compare to kits like brembo and the lot.
Francis
Frachiew;813271 said:
Hi
Francis
Comparing their horsepower
325 =218 hp vs. 320 = 156 hp
You would expect that the 325 brakes if installed onto a 320 will be better than it original brakes. It will be better, but do not expect significant improvement.
Some bros fitted the BMW performance brakes but cannot tell much difference in normal driving condition, so it is also dependent on the driver and whether it is street or track.
bk8singles
