WTS E90(325i) brake kit
Re: WTS E90(325i) brake kit
Bump for you.
Selling E90 325i...
Front Brakes - Disc dimensions:
Vented Discs (300 mm)
Rear Brakes - Dics dimensions:
Direct fit for E90 318i/320i...
Vented Discs (292 mm)
Discs (296 mm)
BIG BUMP for Bro Strauss!!
That is indeed a value for money and truly worthwhile upgrade for any E90 320 owners!
strauss;1022382 said:
Thanks D1X...
Priced to go...asking $200...
strauss;1021633 said:
Taken off 325i from 60k. Ideal / plug & play for E90. Cash & carry. PM me if keen. Cheers!
Hi there,may I know whats the spec of your brake kit?Brand etc.thank you
Anyone can advise of the difference should it be installed on E90 320. Thank you in advance.
** Bumps for Seller!!
E90 320i stock (PFL till 2007) Front 292mm, Rear 296mm
E90 320i stock (LCI) Front 300mm, Rear 300mm
E90 325i (PFL or LCI) Front 312mm, Rear 300mm
E90 335i (PFL or LCI) Front 348mm, Rear 336mm
IMHO, slightly better stopping power when compare 320i with 335i. (est: 10% more) If wants instant differences, BBK (min 4pot, 2pot) is the way to go.. Then again, do u need it? Weight on it & u will be able to decide.
For me, since its due to change pads & disc, I replace it to 335i ones as look so much nicer than stock 300mm disc.. ofcos with e activation of Alvin! MTL~~~ hee...
*ac323 pls thank me! :eek:
Cheers ~~~ :eek:
How about the caliper size?are the caliper size the same?
Bro strauss,howa the pad and rotor life?
I am on E90 320i PFL Performance Brakes 6-pot (Gold)
What is the fit?
$200 per disc i supposed?
sv388ltda
