WTS: RS Chip (Like brand new with 6 months warranty)- $550 firm
ken-y
RS Chip Gen 2, condition like new, installed for only 6 months, still under warranty by Merlin Motor, bought at $7xx including installation, immediate increase in performance, my loss is your gain!
Reason for sale: Change of vehicle and comes with pre-installed chip
Installation: Can be done at Merlin Motor or your own workshop
SMS/Whats app me at 86839393 for fast deal, no reservation, on first come first serve basis, collection near Holland village area, no low baller please as item already priced at very attractive price, can check around all workshops before commiting
RSchip for all types of engines
RSchip is an OBDII device, designed to increase power output in turbo & non-turbo petrol engines. RSchip is an additional control unit, which modifies the engine's factory settings responsible for fuel injections and ignition timing advance in order to maximize power and torque. Values vary dynamically depending on the engine load. RSchip is not a sensor signal modifier. Therefore, there is no risk of the data disruption which could trigger the Check Engine
Is it safe?
«RSchip is completely safe for your engine. It doesn’t overwrite the Electronic Control Unit in your vehicle. Thus, there is no risk of overloading individual engine components. RSchip doesn’t affect your warranty and is untraceable if it needs to be removed».
More power without
using more fuel!
Due to significantly increased torque in the low RPM-range, it’s possible to upshift to the next gear earlier. Your car uses most of its fuel during acceleration. Once you've reached the speed you want, you don't use as much fuel.
for any particular series/car?
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
gemwinrestauranteclubcolo
