WTS: Very low mileage ESS Supercharger 625HP/550nm for E9x M3
hetraa
Legendary 10 Years
VT2-625: Intercooled, 6.5-7PSI system compatible with manual and DCT. 91AKI/95RON or above required. *HFC or cat-delete mid section recommended.
System components:
-Vortech V3 Si-trim supercharger unit.
-Cast aluminum ESS intake manifold with integrated velocity stacks optimized for boost.
-High capacity liquid intercooler system (VT2 only).
-Vortech Maxflow Race bypass assembly.
-High temperature casted plastic intake system for SC -Uni-belt drive system with additional OEM quality rollers.-Heavy-Duty drive belt.
-CNC hard anodized brackets and hardware.-High temperature silicone hoses with clamps
-ESS oil breather assembly designed for boost.
-8 larger Bosch Motorsport fuel injectors, 625 spec.
-K&N high flow air filter.
-ESS E-Flash reprogramming and diagnostic interface.
-Perfectly optimized, dyno tweaked VT2-625 spec MSS60 ECU software with removed top speed governor, calibrated for Spec 2 injectors.
-Detailed, step-by-step installation manual.
-All installation hardware included
-2yr./unlimited mileage warranty.
Installation time: 8-14 hours
VT2-625 specs: Boost pressure: 6.5-7 PSI Intercooled
Horsepower: 625 SAE (~50% gain over stock)
Torque on: 410 ft/lbs Correction factor for drivetrain loss is 15% above RWHP as seen in dynograph (RWHP/0.85)
Application intended for: E90 M3, E92 M3, E93 M3 from 2008-2013
California – For off-road use only.
In my car for around 7k kms. bought ard July 2013. Car total mileage only 30,+++kms since 2012...
Still have unopened supercharger oil bottles.
bot for 11k USD, selling for 9k SGD, if interested kindly SMS me at 96270273.
Re: WTS: Very low mileage ESS Supercharger 625HP/550nm for E9x M3
Bump, Kit is already out of the car...
Price lowered to $8k SGD....sms me at 96270273 :)
Wow...good buy.
Too bad i dun own a car with S65 engine.
Btw, does it work on both the 4.0L and 4.4L ?
works on m3 4.0l only..
pending sale to buyer tmrw...cheers
Congrats on your sales
You scared what ?
You got loads of other things to catch even without opening the bonnet.
End of the day, want mod still scared what.
Supercharger is not an exhaust mod ...... The lta would have an issue with a supercharger ?
supercharge is just air-intake mod right?
Supercharger is connected to the engine don't know which pulley. Considered engine modifications.
Answer to your question = It is a BIG BIG Negative.
This simple diagram says, the idler pulley and alternator.
From what I know, if the vehicle is not forced induction but normal aspirated... yes LTA has an issue with supercharger, it is illegal unless get approval for it. LTA even have issues with force induction cars changing the unit to huge ones.
Ya.
no problems. cant discuss details on open,
but congrats to the new owner, he will be grinning when he gets tire chirp at 1,2,3 gears..
LOL, have already booked my taxi ride with him :)
j88ukcomvn
