X1 boot leaking
Junochy
Hi bro,and sisters.. I have water leaking into the boot where the left side plastic compartment where the wheel key, first aid kit, warning triangle and tool roll is located under the removable panel. Anyone have the same issue .. pls advice ..
The water tank of the BMW X1 is leaking because the material of the water tank has insufficient pressure resistance, causing cracks on the inner wall of the tank until the cracks leak.
thidaihocbrandscom
