Re: 05/05/08 Traction Circle Track Day
MT, please recheck your numbers. At typical lat. accel of around 1G (not looking at spikes) at that driven radius, the apex speeds at T4 are in the 75-80 km/h range. If you are claiming 130km/h apex speeds you're looking at 2.6-2.9 G lateral depending on line and which method of calculation you use. This is not possible for an Evo 9 GSR stock. It is more than twice impossible.
Others may also want to check their numbers. Generally a street car cannot accelerat/decelerate more than 1.2 G long or lat wise and that is being generous.
There's a 700 SGD basic data logger available that will show you the undeniable numbers. Mark Ong the TCC guy sells it. It is very easy to use and is accurate.
High downforce lightweight open wheelers can decelerate at peaks of anywhere from 4.5-5.7 G, upper end being F1 so really are in a class of their own. Hard to compare to most other racecars, much less street cars.
