19" setup
wt_know
i understand the typical/common/standard setup for 19" is 235/35/19 & 265/30/19
however, somehow i don't like it and i feel the tyre is too thin.
let's say, speedometer out is my least concern and i don't care.
my ride is e90 lci, wheel spec is 19x8.5 +32 (front) and 19x9.5 +35 (rear), can i go with
a. 235/40/19 & 265/35/19
b. 235/35/19 & 265/35/19
apart from speedometer out, is there other concerns/issues or change of driving characteristics using the above tyre combination
anyone using the above combo (a) or (b), what's your experience?
if must choose, combo (a) or (b) is better?
thanks !
Re: 19" setup
thanks !
Hi wt_know,
Can I suggest you try: 245 35 19 and 275 30 19?
Re: 19" setup
i did consider this. the tyres are sibei wide for E90 (in my opinion only hor). perhaps for E60/F10 is good.
bro, you use same setup 235/35/19 and 265/30/19 for E90 and E89?
ac323;643754 said:
Hi wt_know,
Re: 19" setup
Hi wt_know,
Yes same set up 235 35 19 and 265 30 19 for both my ride.
Re: 19" setup
Bro wt_know,
Is your ride lowered? If yes, I suggest you dun use anything more than F235/35/19 R265/30/19 in my opinion.
Assuming you didn't lower, I personally feel if you fit F235/40/19 R265/35/19 for E90, it might/should rub the fender. Unless, you opt to roll your fender.
Just my 2 cents worth...not an expert.
Re: 19" setup
car is lowered.
hence, i was exploring higher profile 40/35 instead of 35/30 for tyre width 235/265 (F/R)
Re: 19" setup
If your car can adjust the height - the higher profiles would just need the car height tweaked higher.
Re: 19" setup
great. so using 235/40/19 and 265/35/19 should be less of a problem
this will also help me to clear basement carpark and ridiculous high hump :)
Re: 19" setup
Bro,
U lowered your ride but now yuo want to change to higher profile tyres to clear humps???
Wy dun you just adjust the height then? On a E90, too big tyres (read: heavy) might cause the car to be sluggish..unless you have done the necess mods etc...
Re: 19" setup
haha ... quite contradicting right :lol:
btw, my main reason to lower the car is to close the gap between the tyres and fender. not to slam down the car to the ground :D
what i want to achieve is to have 19" wheel but i don't like thin tyres like 265/30
i know looks and practicality cannot go together. just exploring my options
mohankls;644137 said:
Bro,
Re: 19" setup
hello Mr know
after all your option here is final
you will lead to another headache like
choice of tyre unless you dont mind mixing 2 type of tyre ( to have all same type for this combination may have problem)
problem of tyre size and rim spec matching
Rubbing problem.
To prevent all above, follow what other spec you are safe.
OR since you prefer thicker sidewall go for 18 " (225/40-18 and 255/35-18):thumbsup:
try to learn what is GIVE AND TAKE , your life will be enjoyable one
Re: 19" setup
Hi wt_know
The profile u state are non standard size & will cost alot more as compares with standard (popular) 19'' tire profile.
Just like Front: 235/40/R18 Rear 265/35/R18 tires are somewat on par or higher price as compare with Front 235/35/R19 Rear 265/30/R19 tires. As per roberttan mentioned, it would be a tough task serching for a sets of tires which you prefer.
My nee jiam. :)
Cheers ~~
Re: 19" setup
This is such a useful thread... Planning on installing 19" on my F10 too... Same like bro wt_bro, I do not like thin tyres... And do not like to go too low... I'm very prone to hit kerb and brush big high hump... very heartpain one... hahaha!
Re: 19" setup
BEST you stick with your stock size if you does not want any of the issue you mentioned.
i am talking about stock 17 " ( if 225/55/17):thumbsup:
Re: 19" setup
The problem is buei swee ler... wheels so small... gap from wheel to body so big... :roll: wanna spraypaint the rims to glossy black like the new M5 :)
ae888seekon
