216i GT Owners
Guess petrol variants are a drinker ... but it shd be pretty good driving on mostly expressways/highways
Quick question: Any if you faced an issue with the Nav system? Sometimes when am using it to go to a specific place (I know part of the way). So it either tried to take me on a completely different route, when am actually on the right one, and then just go completely off or state I’ve arrived and navigation just stops.
Asking me to take a left and then a u turn
When I take a right instead of following earlier guidance
Not sure if it's routine base on nav setting. But normally if I know part of route. Will go on and nav will do a refresh. U maybe can play around setting to check if routine given changes?
I need to check since it works sometime and sometime it does not. Currently the rate of failure is higher.
